Left Side of Panel. It is from 0.050" aluminum and will be screwed onto the main panel (with cut outs). Allows maximum flexibility for future changes.
Engine of choice is 0-360, standard igntion/magneto switch will be installed. Toggle switches so allow for E-Mag and P-mag at later date. Top row of switches also has two 5A circuit breakers for the alternator/dyno set up. Electrical being built to allow future updates.
Cut out for Altimeter & Airspeed. Work in progress as I need to finish the Kossman Knob cutout on the airspeed. Most of the hours spent figuring out where to fit things, so redoing such a panen is much quicker.
