Tom's Web Site
Date:  8-26-2012
Number of Hours:  0.00
Brief Description:  Home made nut plate jig
Nutplate jiogs are great time savers.
Most often just use the nut plate to help guide the hole location. No cost tool.
I like drilling the center hole first (#40 or #30) bit. Then use a nutplate jig to center the ears around that center hole. Catch is nutplate jigs are $45 for a new one, $10-$15 on eBay if you're lucky and snag the correct one.
I just keep a hunk of 0-1 flat stock. 0.25" x 1" is fine. Heat cherry red (1450F). Plunge in oil (there is some fancy quenching oil, but for this job nothing too fancy. I did use old motor oil, but use extreme caution as that metal is way above the flash point (common sense applies). Once quenched, toss into a 400F oven for an hour.
Yep, metal welding rod to hang it from the fuselage. Cut, drill to size, and leave to be heated up next time I'm welding something.
Custom nut plate jig -
