Tom's Web Site
Date:  6-15-2012
Number of Hours:  0.00
Brief Description:  Fuselage Weldments for QB folks
Place holder for Fuselage Weldments.
Thanks to the Bearhawk List when I asked 'what would you add'
Easier to think off and list now.
Skylight structure
Electrical subpanel tabs (above foot well)
Battery Support
Battery Support -- future proof for second battery for IFR/Glass Panel
ELT antenna mount in fuselage top
VHF Nav antenna mount in vertical stab
Fuel line supports in door post and under front door to meet the 16" support requirement
Brke line support (hard metal ends, flexible starts) -- under seats.
Trailing edge of optional aluminum panel under front door
Horizontal tube at the front (aircraft forward) end of the radio stack for extra support
4x Seat belt shoulder harness mounting tabs plus extra support tube
Support tab for prop control where it meets the panel, including moving the two factory tabs for throttle and mixture
Remade flap handle to new design
Cap on top of control sticks to accommodate grips and push-to-talk
Seat headrest provisions and fabricate headrests
Headset jack plates (later removed in favor of door jam)
Half of an EMT exhaust system
Fabricate diagonal brace for oil cooler
Tabs for overhead dome/panel flood lights
Landing gear trailing edge mod in case I get bush tires
Perhaps fuel valve support, though not for sure
Tabs for Kydex panels in foot well (Pilot/Copilot) and cargo area.
