Took a while to bend two pieces of 1/2" x 1/2" x 0.035" wall tubing to match the wind root. This will end up as a arched part of the skylight suppor to match the curve of the wings.
3/32" Lexan is being used for the skylight, catch is curve in one direction only.
Hard to see, but I'm slipping the tubing back and and comparing to wing root.
Shop Dog - Part Border Collie, part Retriever. If I'm welding or machining, she patiently sits out side of the shop door and won't let the other dogs in. Once done she waits for me to sweep/vacuum all chips then "inspects" the floor before entering the shop. Only if I could teach her to weld, we have the plane do by now.
