LARRY'S WEB SITE
RV8
Empennage skeleton drilling
Final drilled rear spar, spar doubler and rudder hinge brackets.Drilled all rib to spar attach holes.Clecoed the VS skin to the frame.
Parts temporarily fastened
skin holes taped so I don't make the same mistake as I did last week!
Everything clecoed together. Ready for disassembly, clean up, priming, and then final assembly.
RV8 Home
