GARY'S WEB SITE
Tucano Rs
Install Canopy
Cut M6 stainless steel threaded rod front catch
Fit M6 bolt into nut located on rear carch - treat with loctite 243
Fit threaded rod to front handle - treat with loctite 243
Trial assemble all handles - remove
Check actuator operation - remove rear spring stop - enlarge slot to clear bind - adjust and refit
Design replacement for aluminium catch front and rear
Trial fit canopy frame
Tucano Rs Home
281
Baggage Compartment
Control
Elevator
Hardware
Misc.
Modifications
Trim
Undercarriage
Wiring
