- The 7312XL belt previously installed allowed the alternator to get a little too close to the cowling. The belt was replaced with a 7300XL (slightly shorter belt). - Per manufacturer specs, the Saber hub bolts were torqued to 50 ft-lbs (w/ Loctite) and the Sensenich prop hub bolts were torqued to 65 ft-lbs. - Safety wired alternator mounting bolts
