- Set the fuselage up on sawhorses and removed the false spar - Pulled the wings from the wing stand and started fitting up to fuselage - Several of the larger bolts were temporarily installed in preparation for setting the correct incidence angle and sweep angle. The dihedral angle will be set by the predrilled holes in the spars and the fuselage bulkhead
