Brief Description: Aircraft data plate and builder inspection
-The aircraft data plate was riveted to the passenger side on the fuselage behind the N-number and before horizontal stabilizer. The aircraft data plate contains the following information:
Model: VANS ACFT RV-6A Serial No.: 20634 Engine: Lycoming O-360 Series Gross Wt.:1650 lbs. Registration No.: N52310 Mfg. Date: OCT 2023 Manufactured By: Anthony Rose
- Removed spinner, checked prop angle, retorqued prop hub bolts as specified by Sensenich, and reinstalled spinner.
-The aircraft has been inspected per Part 43, appendix D or other approved programs, and was found to be in a condition for safe operation. This falls inline with experimental amateur built annual condition inspections that will be performed on a yearly basis.
