- Lined the inside edges of the wings with UHMW tape - Installed flaps and set flap angles with recently fabricated (hex stock) flap push rods - Installed ailerons with hardware as specified by drawings - Measured and cut aileron push tubes to final length. Drilled and riveted threaded end connections for rod eye mtg - Installed aileron push rods
