- Cut 1.125” OD X .035” wall tube to 72” lengths (one 12’ piece cut in half) - Marked off 58.75” with tape. This is the approximate length given on the drawing, but the final length will be determined at assembly - Inserted tube threaded ends and rod ends in one side on each tube. These will get drilled and riveted once they have been relocated to the hangar
