- Drilled holes in flaps for push rod mtg - Attached right flap and cut slot for push rod clearance - Drilled 1/4” hole through flap bar to connect push rod - Set flap angles to 0, 10, 25, and 40 degrees on control unit - Tested unit for consistency at various flap angles
