- Wings set in place with several bolts through the spar - Alignment of wings checked for sweep and incidence angles - 5/16 holes drilled through the rear spar attach brackets and bolts installed (success!) - Plane temporarily removed from saw horses while wing root fairings and tank attach brackets are being worked on
