- Added and aluminum strip to the front of the air box; drilled holes and riveted in place - Drilled holes and added plated nuts - Test fit the assembly of components - Added a mtg plate to the top of the air box mtg frame. This plate will provide more rigidity and flatness when mtg to the Rotec TBI. - High temp painted the air box - Primed the air box mtg frame
