Tony's RV-6A Web Site
Date:  3-19-2023
Brief Description:  Alternator belt change
- The 7312XL belt previously installed allowed the alternator to get a little too close to the cowling. The belt was replaced with a 7300XL (slightly shorter belt).
- Per manufacturer specs, the Saber hub bolts were torqued to 50 ft-lbs (w/ Loctite) and the Sensenich prop hub bolts were torqued to 65 ft-lbs.
- Safety wired alternator mounting bolts
