- Added filler piece to cover up the slot in the fuselage that the windscreen transitions through from outside of the fuselage to inside of the fuselage. These pieces also help secure the windscreen against the side of the fuselage. - Primed and painted filler pieces - Riveted filler pieces in place
These filler peices will be covered with fiberglass on the outside as part of the windscreen fairing.
