- Added 1N4007 diode between the battery contact and switch to ground contact. The diode will prevent arcing at the master switch when the relay is de-energized. Electrical path details are documented on the attached image.
- Located drilled, and mounted master relay, starter relay, and current limiting ANL fuse.
