Brief Description: Left and Right Seat Belt Attach Angles
Completed both left and right seat belt attach angles. Moderately complicated. I made the larger 1" radius using a 2" diameter washer as a template, worked perfectly. Since this was a fairly shallow radius made initial cut with bandsaw, then finished with roundover file, chainsaw file, flap sander in die grinder, and finally small scotch-brite wheel.
