Anthonys Web Site
Date:  8-16-2012
Number of Hours:  3.50
Brief Description:  D6 audio and GRT audio wiring - pitot static syste
Ran wires from the adjustable resister to the panel ground where it was labeled and secured.
Ran wires from the D6 adjustable resister to the rear of the audio panel.
Ran wires from the rear of the GRT Sport EFIS to the audio panel, one for audio which attaches to pin 20 on the sport and the other a gray ground wire from pin 23 on the GRT Sport to the rear of the audio panel.
Installed the alt static switch and attached the static lines to the switch.
Completed the installation of the static line to the air switch and the rear of the D6 and Sport EFIS's, using a Y fitting.
