Anthonys Web Site
Date:  6-25-2012
Brief Description:  wired clock to battery - confirmed fuseblock conne
I finished wiring the clock/Gmeter directly to the battery. I installed a fuseblock next to the battery. The correct fuse is .5 amp however I used a 1amp because it was the smallest I had.
I also sorted out more fully the connections to the fuseblocks. I modified the diagram of the fuseblock connections with a high degree of confidence in its accuracy.
When I turned on the master switch I was rewarded by seeing the face of the clock show a number, which was 1 for 1G. I installed a 1 amp fuse in the correct slot in the aux master fuseblock and was rewarded by a nice orange glow of backlight on the clock. WhoooHoooo.
