Anthonys Web Site
Date:  10-10-2011
Number of Hours:  6.00
Brief Description:  avionics ground block replaced, power and ground c
Realized that the avionics ground bus would be too small to meet the need. I shopped at Skycraft and found a larger bus. I removed the old bus and replaced it with a new larger one.
Reconnected the ground wires to the new bus.
Made power and ground connections to the Dynon D6 and Audio Panel. I will have to extend thew power wires for the transponder and the GRT.
