Anthonys Web Site
Date:  9-12-2011
Number of Hours:  2.50
Brief Description:  Avionics wiring D6 gps to EFIS
I did a couple of build sessions since the last one without logging them.
Tonight I made up 22awg power and ground wires from red and black for the Dynon D6 backup EFIS. I labeled the wires and installed them.
Also removed a pin that had broked off in a hole in the GRT connector. Insalled another pin on the wire and reinstalled the wire into the GRT connector.
Installed the gray/red wire supplied by GRT into pin 30 on the GRT. Spliced that wire to the blue wire from the garmin 396 gps.
Dressed up the wire runs, especially the ground and power wires.
