Brief Description: battery cables, main bus feed, trim wire
I made up two #4 cables at skycraft and checked them for fit. They fit. The #6 awg wire that will run from the battery relay out side to the main bus was also fabricated. It is just a little long but will work, however the holes on the end fittings are two small to attach to the battery relay and main bus.
Stacy Fletcher helped my run the wire for the trim servo aft through the tailcone.
