Brief Description: roller rail cleaned and polished
22 April 07 - 1 hour
Reassembled the roller mechanisms that I had taken apart to paint. I used very thin Teflon material that I bought from skycraft to make washers that I used on the bearing surfaces in an effort to make them slide more smoothly.
I cleaned up the port side roller rail using gray and maroon scotchbright pads and some sandpaper in places. I then used the Harley Davidson metal cleaner in a spray can. I am a bit tired from a long day at sun and fun, so I did not install the rail tonight.
