Anthonys Web Site
Date:  3-2-2007
Brief Description:  cabin heat routing
2 March 07 -2 hours
Cut hole for air vent on the baggage bulkhead. I originally cut a hole a tad over 2 inches with a hole cutter in my drill press. I realized that the hole had to be much larger for Vans air vent to fit into it. I spend about an hour and used 3 dremel sanding drums to enlarge the hole. I drilled four holes in the corners to attach the mounting plate.
