Anthonys Web Site
Date:  2-25-2007
Number of Hours:  3.00
Brief Description:  wiring FPS, stick, boost pump, speaker
2/25/07- 3 hours
Wired the white/blue wires from the flap and trim position indicator lights to the common ground on the FPS box. I joined the two wires from the position indicators to another wire with a butt splice. I then joined that wire with the two white/blue wires from the flap and trim position sensors with a butt splice. An additional wire runs from that butt splice to position 3, common ground, on the FPS box. I had to do this because there is not enough room in the port on the FPS box to install all the wires there.
Wired the boost pump to the relay. The ground from the pump goes to the firewall ground block. I installed a 10 awg wire into the Master fuseblock and ran it to the relay 12v in. I ran a 10awg wire from the relay to the red wire on the pump. I grounded the relay to the panel ground block with an 18 awg wire. I attached the black/white wire from the stick cable to the relay switch position.
I installed the speaker on the z bracket “shelf” with two #8 screws.
Attached the panel ground wire to the firewall ground block. It had not been attached because I did not have a fast on connector for #10 awg wire until now.
