Anthonys Web Site
Date:  4-2-2007
Brief Description:  wiring starter contacor, start warn light FPS
2 April 07 2 hours.
Removed battery tray and cut away a section of the corner that interfered with the starter contactor I lead.
Connected a 20 awg wire from the starter contactor I lead to the starter warning light on the panel. I put an inline fuse holder near the starter contactor and labeled it “starter warn”.
Labeled and connected the ground wire from the starter contactor to the firewall ground.
Removed the left end jumper on the panel ground block to make that cell on the left end available for the fps grounds which connect to port 3 on the fps box. There are too many wires to connect to the box. I will run most of the wires to the six tabs on the left end cell of the panel ground block and one large wire from that cell to the fps box port 3.
