Worked on the trim motor power issue. I determined that power comes from the 12v bus to the circuit breaker on the panel, then out to the trim relay on the FPS. It does not go back to the trim motor.
The flap motor power does the same thing...goes from the circuit breaker to the flap relay, then seems to go to the FPS (or somewhere). The flap motor will actuate from the flap switch on the stick. The trim motor will not.
