Brief Description: drop down tray for FPS, installing nutplate
I removed several panel items to clear the area of the bottom of the panel where the fastener for the drop down tray for the FPS will go.
Drilled a hole for the fastener. Drilled a hole for the nutplate. The hole for the nutplate rivet does not line up properly. I will have to continue this tomorrow.
