Anthonys Web Site
Date:  9-14-2012
Number of Hours:  3.00
Brief Description:  Attachement of Vertical and Horizontal stabs
Worked on the attachment of the HS and VS. It is finally coming together in my head. I spent time looking at the plans and examining the airframe. I fitted the 4 bolts on the forward end of the HS, but could not get all of them seated. The spacer holes do not align perfectly causing the bolts to not fit through the spacer while aligned with the hole underneath.
