Finalized the switch layout. I moved the labels on the switches on the left side of the panel. I switched the green wires from each of the position indicators (trim and flaps) so that the indicator on the left will be trim and the one on the right will be flaps. That reversed positions 3 and 5 on the relay.
Installed a pin on the end of the wire leading form the auto pilot switch to the fuseblock and installed the wire with the pin into slot 9 on the main fuseblock.
