Brief Description: completed power and ground connections
Completed the power and ground connections for all avionics devices.
It took quite a bit of time. You would think this could be done in a couple of hours. Not so. Running each wire through the wiring bundle and labeling took time. I crimped n the connectors to the blue sea fuse block but did not insert the connectors. I need to determine their orientation.
