Anthonys Web Site
Date:  7-27-2011
Number of Hours:  4.00
Brief Description:  installing the radio stack
Went to skycraft and procured several #6 nylock nuts and 100 feet of awg 24 tefzel wire.
Opened the holes in the panel for the screws that attach the clock. Moved the clock to align so that the lettering was level. Tightened the screws. That should work.
I nstalled the radios and other components for the radio stack into the panel. Bolted each tray to the panel beginning at the bottom and working up. They all fit pretty well except for the top tray housing the audio panel. tt was just a bit proud of the front of the panel and the right side was just a few thousands further forward than the left side.
I drilled the holes a little larger and did other things to tweak the alignment. In the end, it just got worse. I gave up for the night. Dick Isherwood helped.
