Anthonys Web Site
Date:  5-18-2011
Brief Description:  EIS wiring
Flew up to Mid Florida airport today, while getting my instrument currency, and picked up the fuel hose and flow scan from Malcom Powell. He was not able to address the issue of the fuel hose which was cut in the middle and needs steel ends put on so that I can put the flowscan device in the middle, or flare the short piece between the pump and the firewall. This was not counted in todays time log.
Attached the 4.8v block, temporarily, to the airframe. Attached thew blue wire from the EIS to the block.
Cut the orange wire and attached each end of the cut to the 4.8v block. Labeled each end.
