Anthonys Web Site
Date:  4-27-2010
Number of Hours:  1.00
Brief Description:  fuel hose from servo to divider
I worked on the placement of this hose. I made a hole in the back baffle to run the hose through and discovered that the hose is 1 to 2 in short if it runs through that hole. It may work if I make another hole further down the baffle, but then again it may still be too short.
I have to decide whether to install the flowscan 201 transducer in this line, which will make its length moot, or not.
I also cleaned up the shop.
