Fabricated the spacer for the aft port corner near the oil cooler. Drilled the flanges on that corner as well as the spacer.
Much of the time was spent fabricating the angle support piece that has to be hand shaped with a file. This piece goes from the left lower section of the port aft side baffle section to the upper right corner of that section. A bit of final shaping remains to be done.
I removed the support piece that would have been used if I was not installing the baffle mounted oil cooler.
