Anthonys Web Site
Date:  7-12-2008
Number of Hours:  3.00
Brief Description:  EIS probes and Spinner plate
Englared the holes in the spinner plate to fit onto the prop extension using a dremel.
Installed the CHT probes in the cylinders. The fittings go in first and you attach the bayonet fittings on the probes to the fittings installed in the cylinders.
Taped up the ends of the exhaust to prevent air and moisture entering the engine. Fogged the cylinders and heated the dissident crystals to make them blue again.
Determined the location of the oil temp sensor but did not install it.
