Anthonys Web Site
Date:  2-17-2008
Number of Hours:  3.00
Brief Description:  baggage door hinge, forward top skin
Finished making the hinges for the forward baggage door. I realized that there is a spacer that goes between the top of the hing bracket and the skin. I fabricated that per plans.
Worked on the topskin/firewall connection. I had feared that the holes would not line up between the topskin and firewall where I had match drilled them long ago. When I first drilled them, I forgot that a .025 spacer went between the topskin and firewall. Tonight I drilled through the spacer from the top of the topskin and found that most of the holes line up. The bottom 6 rivet holes on the starboard side don't line up exactly. I did not drill or cleco them. I drilled and clecoed about half of the holes between the topskin and firewall, drilling through the .025 spacer at each of those holes.
