Anthonys Web Site
Date:  1-20-2008
Number of Hours:  3.00
Brief Description:  control linkages
Connected the aft stick to the control pushrod that leads aft. It was tricky because of the two washers that you have to put alongside the bearing.
Connected the forward stick to the control column, I spent a good amount of time making the brass bushing the right length. I installed the stick. I still have to attach the pushrod to the bottom of the stick.
