Anthonys Web Site
Date:  1-5-2008
Number of Hours:  1.50
Brief Description:  landing gear, install brake part to flange
I installed the brake flange on the left landing gear using the AN4-11 bolts that I recieved from skybolt. I did not have an AN4-5 as specified, so I used an AN4-6 instead on the lower left hole in the flange and brake part. I had to make new spacers.
I installed the wheel and tire on the right axle and checked to see that the safety wire holes in the axle lined up with the holes in the nut.
I installed the wheel and tire on the left axle and marked the axle threads with a sharpie and center punch. I did not drill the left axle safety wire holes yet.
