Brief Description: enlarged canopy holes for fasteners
I noticed earlier that the canopy does not fit the frame exactly, resulting in 3 places where the holes in the canopy do not match with the holes in the frame. I bought a 1/8 dremel stone from Sears and used it to open those holes so that the fastener, #4 SS screw, would go through both the frame and the canopy. I removed the tape from areas where the fastener nut would be installed on the inside of the canopy frame all around.
I would have applied sikaflex, but the temp was at 90 deg F, the upper limit for sikaflex application.
