Finished installing the nutplates for the removable baggage compartment floors.
Decided to add two access panels in front of the canopy.. I am spoiled by the great access to the back of my RV-4 panel, and decided I could live with the somewhat ugly panels with multiple screws for the convenience of getting to the back side of the sub bulkhead in the RV-7. I also am not using the quick release canopy pins, so this will allow me good access to the hinge bolts when I need to remove the canopy. Used a cutoff wheel in my Dremel tool to make the straight cuts (clamped on a piece of angle to use as a guide to get the cuts straight) I then used the rotary cutting attachment for the dremel to make the curved cuts (after using my unibit to drill the starter holes)
