Re-checked wing sweep with plumb bobs and stringline. Checked and adjusted the wing incidence angle by placing a level with a 3" spacer from the main spar to the rear spar, and using the digital level. Both wings were set to "0" on the level, which equates to a 1 degree positive angle of incidence. Checked several points along each wing and all were zero on the level.
