Brief Description: Completed holes in fuselage for gear weldment
Located gear mount cut out holes in fuselage bottom with template cut from plans. Took a lot of trial and error to get the holes right. Also had to remove two nutplates from the spar flange to allow gear mount to slip down properly.
