Toms Web Site
Date:  2-25-2009
Number of Hours:  4.30
Brief Description:  Fuel vent line fabrication
Fabricated and installed both left and right fuel vent lines. Yes, the pro seal around the NACA vent is a mess, but that will be cleaned up... Sanded off the threads of the vent line bulkhead fittings, and cut 45 degree angles on the bandsaw. Also made a doubler for the parking brake valve and drilled to the firewall. Awaiting delivery of AN fittings from Summit racing to install brake lines.
