Worked more on filing the paint gap between cowl halves as well as the firewall. Marked and cut out the oil filler access door with my Dremel. Cut the separate access door to fit the recessed cowl. It doesn't sit very well in the opening. I suspect I'll use aluminum for the door instead of the fiberglas piece supplied...
