Toms Web Site
Date:  3-25-2013
Number of Hours:  4.00
Brief Description:  More Skybolt fastener work
Used the supplied Skybolt jig to drill the attach holes for the recepticles, then countersunk the holes.Installed the cowl and drilled every other hole. I wanted to drill in assembly so the unibit would have the .050 aluminum underneath as a guide, instead of just the thin fiberglas. Then I took the cowl and attach strips off the plane, cleco'd the strips back on the cowl and used C clamps to clamp the strips tightly. Removed the cleco's and drilled the remaining holes.
Took everything apart AGAIN, and drilled the large holes in the strips to their final size.
Skybolt drill jig
Skybolt drill jig
All strips finish drilled and ready to prime and install the recepticles
