Brief Description: Drilled engine mount to firewall
Lined up the engine mount the best I could using the pre drilled 1/4" holes in the four corners of the firewall. They didn't match up all that well, so I marked the direction each hole needed to be enlarged, and whipped out the dremel with a metal cutting bit. Got the holes very close, then drilled the 3/8" holes through the mount and firewall. Worked well...
