This is when it starts to look like a plane. This is the tail that sticks out behind the passenger compartment. Unfortunately, as soon as it is all assembled (to check alignment), it must all be taken apart to deburr the metal, clean it, prime it.After that, I put it all back together slowly as each part is riveted.The tailcone is started by working on the bottom upside down. Frames and bulkhead were assembled and clecoed together.
