1. All the skeletal parts after the three part priming process. This doesn't include the spars and skins.2. Here you have the rear spar and ribs being attached. This happens 4 times in this section. A top and a bottom skin for left side and right side.3. Shows the completed elevators. If you notice the notch area in each elevator, this is where the trim tabs will go.This whole assembly had an incredible amount of detail work related to drilling, deburring, clecoing and riveting many, many of the parts you saw in the past few pictures
